当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Insert the new lever starting with the left side while it is tilted downwards.
Tilt the lever up so that the lever on the left is fully inserted.
Squeeze the right side of the lever to Insert the right side of the lever.
Put the right side of the lever into the drill in the mowers handle.
一条评论
I have a Greenwork 40 volt electric mower. I start it up correctly (first push down the start button, and as it is pushed down, then pull back on the starter lever. Suddenly, it shuts off now after 1 or 2 seconds. This occurs repeatedly and the mower is not operational. The two batteries are fully charged. Any suggestions?
v15venable - 回复
