简介
Electric mowers differ from motor mowers that require pulling the starter fast and requires strength, which can cause frustration. Electric mowers are much more efficient to start. However, the lever can often break as they are hollow and fragile. While the replacement is easy, there are not many guides available. This guide will give you a step by step to replace a lever and the ability to resolve the issue of the lever not moving smoothly.
你所需要的
As seen in the picture, the lever is snapped on one side of the lever and needs replacement.
Now that the lever is replaced be sure to be gentle with pull the lever back and placing the mower down. This will avoid future issues and another replacement.
一条评论
I have a Greenwork 40 volt electric mower. I start it up correctly (first push down the start button, and as it is pushed down, then pull back on the starter lever. Suddenly, it shuts off now after 1 or 2 seconds. This occurs repeatedly and the mower is not operational. The two batteries are fully charged. Any suggestions?
v15venable - 回复
