跳转到主内容
GravityLight Mounting Post Replacement and Spring Replacement
你所需要的
  1. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: 步骤 1 中的图像 1,2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: 步骤 1 中的图像 2,2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Mounting Post Replacement and Spring Replacement, Opening the Device Housing: 步骤 2 中的图像 1,1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Back Panel Screws: 步骤 3 中的图像 1,1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  4. GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 步骤 4 中的图像 1,3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 步骤 4 中的图像 2,3 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 步骤 4 中的图像 3,3
    • Firmly grasp both parts of the back panel and pull them apart.
  5. GravityLight Mounting Post Replacement and Spring Replacement, Orienting the Middle Section: 步骤 5 中的图像 1,1
    • Place the middle section on a sturdy surface.
    • Move any wires in front of the mounting post.
  6. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: 步骤 6 中的图像 1,2 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: 步骤 6 中的图像 2,2
    • Push down on the spring.
    • The spring is very stiff. Compressing the spring requires a moderate amount of force.
    • Push the spring and the mounting post away from the middle section and remove them from the pocket.
  7. GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: 步骤 7 中的图像 1,2 GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: 步骤 7 中的图像 2,2
    • Pull the mounting post out of the inside of the spring
结论
Jamie Forslin
于09/26/14注册
143 声望
撰写一个指南
团队
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G2
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 815
