跳转到主内容
GravityLight Internal Gears Replacement
你所需要的
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: 步骤 1 中的图像 1,2 GravityLight Internal Gears Replacement, Removing the Front Panel: 步骤 1 中的图像 2,2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: 步骤 2 中的图像 1,1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: 步骤 3 中的图像 1,1
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: 步骤 4 中的图像 1,1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: 步骤 5 中的图像 1,1
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: 步骤 6 中的图像 1,1
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: 步骤 7 中的图像 1,2 GravityLight Internal Gears Replacement, Removing Internal Gears: 步骤 7 中的图像 2,2
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
结论
团队
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G2
5 名成员
创作了7篇指南
1指南评论
Where can we find the replacement gears?
fb - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 3,248
