跳转到主内容
GravityLight Dial Replacement
你所需要的
  1. GravityLight Dial Replacement, Removing the Front Panel: 步骤 1 中的图像 1,2 GravityLight Dial Replacement, Removing the Front Panel: 步骤 1 中的图像 2,2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: 步骤 2 中的图像 1,1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: 步骤 3 中的图像 1,1
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: 步骤 4 中的图像 1,2 GravityLight Dial Replacement, Popping the Dial out: 步骤 4 中的图像 2,2
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: 步骤 5 中的图像 1,1
    • Fully remove the dial by pulling it out from the front.
结论
团队
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 的会员
CPSU-FORTE-F14S12G2
5 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 861
