跳转到主内容
Graco Secure Coverage Parent Unit Power Jack Replacement
你所需要的
  1. Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: 步骤 1 中的图像 1,3 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: 步骤 1 中的图像 2,3 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Battery: 步骤 1 中的图像 3,3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Power Jack: 步骤 3 中的图像 1,2 Graco Secure Coverage Parent Unit Power Jack Replacement, Parent Unit Power Jack: 步骤 3 中的图像 2,2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 4 中的图像 1,2 Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 4 中的图像 2,2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases.
  5. Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 5 中的图像 1,1
    • Pry the edges of the device to separate the front case away from the rare case.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 6 中的图像 1,2 Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 6 中的图像 2,2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
  7. Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 7 中的图像 1,2 Graco Secure Coverage Parent Unit Power Jack Replacement: 步骤 7 中的图像 2,2
    • Pick up the motherboard carefully to look at the power jack wires.
    • Solder off power jack from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack.
    • Replace the power jack.
结论
Omar Abdullah
于09/06/15注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 157
