跳转到主内容
Graco Secure Coverage Parent Unit Battery Replacement
你所需要的
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 步骤 1 中的图像 1,3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 步骤 1 中的图像 2,3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 步骤 1 中的图像 3,3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
结论
Rogelio Morales
于08/31/15注册
201 声望
创作了2篇指南
团队
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 的会员
USFT-REMMELL-F15S6G5
4 名成员
创作了8篇指南
一条评论
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 736
