跳转到主内容
Graco Literider Classic Connect Seat Replacement
你所需要的
  1. Graco Literider Classic Connect Seat Replacement, Seat: 步骤 1 中的图像 1,2 Graco Literider Classic Connect Seat Replacement, Seat: 步骤 1 中的图像 2,2
    • Flip the stroller over so the back of the seat points upward.
    • Locate the twelve 12 mm Phillips screws holding the fabric to the frame of the stroller. Six are found along the back of the seat, and the other six are along the bottom of the seat.
  2. Graco Literider Classic Connect Seat Replacement: 步骤 2 中的图像 1,2 Graco Literider Classic Connect Seat Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the twelve 12 mm screws and set them aside.
  3. Graco Literider Classic Connect Seat Replacement: 步骤 3 中的图像 1,2 Graco Literider Classic Connect Seat Replacement: 步骤 3 中的图像 2,2
    • Locate the two buttons holding the fabric basket frame on either side of the stroller.
    • Unbutton the two buttons.
  4. Graco Literider Classic Connect Seat Replacement: 步骤 4 中的图像 1,2 Graco Literider Classic Connect Seat Replacement: 步骤 4 中的图像 2,2
    • Locate the three velcro straps holding the seat to the canopy.
    • Undo the three straps.
  5. Graco Literider Classic Connect Seat Replacement: 步骤 5 中的图像 1,1
    • Remove the seat from the frame.
    • When replacing the seat on the frame, some additional force may be required to insert the screws into their proper places.
结论
另外一个人完成了本指南。
Tyler Laird
于09/29/15注册
540 声望
创作了3篇指南
团队
Cal Poly, Team 11-4, Forte Fall 2015 Cal Poly, Team 11-4, Forte Fall 2015 的会员
CPSU-FORTE-F15S11G4
5 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 22
总计 1,078
