跳转到主内容
Governor Adjustment
你所需要的
  1. Governor Adjustment, Governor Adjustment: 步骤 1 中的图像 1,3 Governor Adjustment, Governor Adjustment: 步骤 1 中的图像 2,3 Governor Adjustment, Governor Adjustment: 步骤 1 中的图像 3,3
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
  2. Governor Adjustment: 步骤 2 中的图像 1,1
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
  3. Governor Adjustment: 步骤 3 中的图像 1,1
    • Carefully re-hook the spring on the arm it was disconnected from.
结论
Aaron Correya
于04/19/18注册
239 声望
创作了2篇指南
团队
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G15
4 名成员
创作了7篇指南
2指南评论
Wow, I'm very grateful.
Bradley Earnest - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 2,949
