简介
Use this guide to remove the thumbsticks in your Google Stadia controller.
Although you don't need special tools to open the Google Stadia controller, the opening process is difficult and requires a lot of force. The case of the controller is held together by super tight plastic clamps which require a tool solid enough to withstand the pressure it takes to pry them open. Take your time and try not to get frustrated during the opening procedure—otherwise you're likely to scratch or otherwise damage your controller.
你所需要的
Apply a heated iOpener to the rear side of the Stadia controller where the screw cover is located to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Insert the tip of an opening pick into the gap between the plastic screw cover and the rear case of the controller.
Slide the opening pick along the screw cover to slice the adhesive.
Use a pair of tweezers or your fingers to remove the screw cover.
Use a Torx T8 screwdriver to remove the 9.6 mm-long screw securing the rear case.
The front cover assembly of the Stadia controller is held in place by various tight plastic clamps. They are very hard to open and snap back in place easily.
Insert a Jimmy into the gap between the front and back cover assembly at the inside of the left controller handle.
Tilt the Jimmy upwards and push it into the gap between the covers at the same time to pry open the plastic clamp. You should hear a clack noise once the clamp pops open.
Insert an opening pick in a steep angle into the gap you created to prevent the first clamp from popping back into its closed position.
Insert a Jimmy into the gap between the front and back cover assembly at the outside of the left bottom end of the controller handle.
Repeat the previous opening procedure to open the three plastic clamps at the outside of the left controller handle.
Insert a Jimmy into the gap between the front and back cover assembly between the left shoulder button and the charging port at the top edge of the Stadia controller.
Repeat the previous procedure at the clamp between the right shoulder button and the charging port.
Insert a Jimmy into the gap between the front and back cover assembly at the bottom edge of the Stadia controller right to the headphone jack.
Repeat the previous procedure at the clamp left to the headphone jack.
Carefully lift the front cover assembly and fold it to the left side of the Google Stadia controller.
Use your fingers to remove the right thumbstick by pulling it upwards and off the right joystick.
Use your fingers to remove the left thumbstick by pulling it upwards and off the left joystick.
2等其他人完成本指南。
