跳转到主内容
Google Pixelbook Right Charging Port Replacement
你所需要的
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 步骤 1 中的图像 1,3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 步骤 1 中的图像 2,3 Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): 步骤 1 中的图像 3,3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: 步骤 2 中的图像 1,2 Google Pixelbook Right Charging Port Replacement: 步骤 2 中的图像 2,2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: 步骤 3 中的图像 1,3 Google Pixelbook Right Charging Port Replacement: 步骤 3 中的图像 2,3 Google Pixelbook Right Charging Port Replacement: 步骤 3 中的图像 3,3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: 步骤 4 中的图像 1,3 Google Pixelbook Right Charging Port Replacement: 步骤 4 中的图像 2,3 Google Pixelbook Right Charging Port Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: 步骤 5 中的图像 1,2 Google Pixelbook Right Charging Port Replacement: 步骤 5 中的图像 2,2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: 步骤 6 中的图像 1,2 Google Pixelbook Right Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: 步骤 7 中的图像 1,1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: 步骤 8 中的图像 1,2 Google Pixelbook Right Charging Port Replacement, Right Charging Port: 步骤 8 中的图像 2,2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: 步骤 9 中的图像 1,1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: 步骤 10 中的图像 1,1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: 步骤 11 中的图像 1,1
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: 步骤 12 中的图像 1,1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: 步骤 13 中的图像 1,2 Google Pixelbook Right Charging Port Replacement: 步骤 13 中的图像 2,2
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
结论
Alon Gary
于01/24/18注册
544 声望
创作了2篇指南
团队
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G1
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,580
