跳转到主内容
加入维修社区 - 创建账户
Google Pixelbook Motherboard Replacement
你所需要的
  1. Google Pixelbook Motherboard Replacement, Battery (Back Panel): 步骤 1 中的图像 1,3 Google Pixelbook Motherboard Replacement, Battery (Back Panel): 步骤 1 中的图像 2,3 Google Pixelbook Motherboard Replacement, Battery (Back Panel): 步骤 1 中的图像 3,3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    添加评论
  2. Google Pixelbook Motherboard Replacement: 步骤 2 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    询问修复机器人
    添加评论
  3. Google Pixelbook Motherboard Replacement: 步骤 3 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 3 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 3 中的图像 3,3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    添加评论
  4. Google Pixelbook Motherboard Replacement: 步骤 4 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 4 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    询问修复机器人
    添加评论
  5. Google Pixelbook Motherboard Replacement: 步骤 5 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    添加评论
  6. Google Pixelbook Motherboard Replacement: 步骤 6 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the small, black casing by using the spudger to lift it up from its place.
    添加评论
  7. Google Pixelbook Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    询问修复机器人
    添加评论
  8. Google Pixelbook Motherboard Replacement, Left Charging Port: 步骤 8 中的图像 1,2 Google Pixelbook Motherboard Replacement, Left Charging Port: 步骤 8 中的图像 2,2
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
    询问修复机器人
    添加评论
  9. Google Pixelbook Motherboard Replacement: 步骤 9 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
    询问修复机器人
    添加评论
  10. Google Pixelbook Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
    询问修复机器人
    添加评论
  11. Google Pixelbook Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
    询问修复机器人
    添加评论
  12. Google Pixelbook Motherboard Replacement: 步骤 12 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
    询问修复机器人
    添加评论
  13. Google Pixelbook Motherboard Replacement: 步骤 13 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 13 中的图像 2,2
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
    询问修复机器人
    添加评论
  14. Google Pixelbook Motherboard Replacement: 步骤 14 中的图像 1,1
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
    询问修复机器人
    添加评论
  15. Google Pixelbook Motherboard Replacement: 步骤 15 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 15 中的图像 2,2
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
    询问修复机器人
    添加评论
  16. Google Pixelbook Motherboard Replacement, Right Charging Port: 步骤 16 中的图像 1,2 Google Pixelbook Motherboard Replacement, Right Charging Port: 步骤 16 中的图像 2,2
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
    添加评论
  17. Google Pixelbook Motherboard Replacement: 步骤 17 中的图像 1,1
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
    询问修复机器人
    添加评论
  18. Google Pixelbook Motherboard Replacement: 步骤 18 中的图像 1,1
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
    添加评论
  19. Google Pixelbook Motherboard Replacement: 步骤 19 中的图像 1,1
    • Remove the small, red component by lifting it up with the spudger.
    询问修复机器人
    添加评论
  20. Google Pixelbook Motherboard Replacement: 步骤 20 中的图像 1,1
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
    询问修复机器人
    添加评论
  21. Google Pixelbook Motherboard Replacement: 步骤 21 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 21 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
    询问修复机器人
    添加评论
  22. Google Pixelbook Motherboard Replacement, Motherboard: 步骤 22 中的图像 1,2 Google Pixelbook Motherboard Replacement, Motherboard: 步骤 22 中的图像 2,2
    • Disconnect the flat, black cord from the motherboard by using a spudger to push it upwards out of the slot, or by using your hand to carefully pull upward.
    询问修复机器人
    添加评论
  23. Google Pixelbook Motherboard Replacement: 步骤 23 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 23 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 23 中的图像 3,3
    • Fold back the plastic covering on the motherboard using the nylon spudger.
    询问修复机器人
    添加评论
  24. Google Pixelbook Motherboard Replacement: 步骤 24 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 24 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 24 中的图像 3,3
    在这个步骤中使用的工具:
    • Disconnect the two black cables from the motherboard by pulling the connectors upward using the needle-nose tweezers.
    询问修复机器人
    添加评论
  25. Google Pixelbook Motherboard Replacement: 步骤 25 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 25 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 25 中的图像 3,3
    • Disconnect the flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
    添加评论
  26. Google Pixelbook Motherboard Replacement: 步骤 26 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 26 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 26 中的图像 3,3
    • Disconnect the large flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
    询问修复机器人
    添加评论
  27. Google Pixelbook Motherboard Replacement: 步骤 27 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 27 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 27 中的图像 3,3
    • Raise the retaining latch of the motherboard connector by using the needle-nose tweezers.
    • Disconnect the large flat cable from the motherboard by gently pulling on the latch using the needle-nose tweezers.
    询问修复机器人
    添加评论
  28. Google Pixelbook Motherboard Replacement: 步骤 28 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 28 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 28 中的图像 3,3
    • Disconnect the flat cable from the motherboard by using the needle-nose tweezers to gently pull the connector out of the slot.
    添加评论
  29. Google Pixelbook Motherboard Replacement: 步骤 29 中的图像 1,2 Google Pixelbook Motherboard Replacement: 步骤 29 中的图像 2,2
    • Remove the gold 3.0mm screws and the black, flat 2.0mm screws from the motherboard by using a T3 Torx screwdriver to turn the screws counterclockwise.
    添加评论
  30. Google Pixelbook Motherboard Replacement: 步骤 30 中的图像 1,3 Google Pixelbook Motherboard Replacement: 步骤 30 中的图像 2,3 Google Pixelbook Motherboard Replacement: 步骤 30 中的图像 3,3
    • Remove the motherboard by gently lifting it out of the laptop using the needle-nose tweezers.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
9等其他人完成本指南。
Logan Lawson
于01/24/18注册
410 声望
撰写一个指南
团队
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 的会员
CPSU-LIVINGSTON-W18S18G1
4 名成员
创作了9篇指南
14指南评论
This would be much more helpful if all the “components” being removed were identified.
TIA,
R
rocwoof - 回复 分享
You’ve put together a very good procedure for replacing a motherboard. My pixelbook needs a motherboard. Where can I buy one? Google does not sell them.
Tony Meier - 回复 分享
Tony Meier - 回复 分享
I believe the step8 & step16 mentioned “charging port“ shall be the loudspeaker in fact.
baokai zheng - 回复 分享
It’s bad instruction to pull cable out without unlocking the retaining tab, also it’s impossible to put cable back while the connector is still in locking position. Never pull a cable while it’s locked in the connector, this practice is only used by novices.
nabe_03 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 92
总计 16,533
