跳转到主内容
Google Pixelbook Go Right Charging Port Replacement
你所需要的
  1. Google Pixelbook Go Right Charging Port Replacement, Back Panel: 步骤 1 中的图像 1,2 Google Pixelbook Go Right Charging Port Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Flip the device so that the back is facing up.
    • Peel the rubber stoppers off the top and bottom of the device.
  2. Google Pixelbook Go Right Charging Port Replacement: 步骤 2 中的图像 1,2 Google Pixelbook Go Right Charging Port Replacement: 步骤 2 中的图像 2,2
    • Remove ten 3 mm screws from around the edge of the back panel using a T5 Torx screwdriver.
  3. Google Pixelbook Go Right Charging Port Replacement: 步骤 3 中的图像 1,3 Google Pixelbook Go Right Charging Port Replacement: 步骤 3 中的图像 2,3 Google Pixelbook Go Right Charging Port Replacement: 步骤 3 中的图像 3,3
    • Use an iFixit opening tool to pry up the back panel cover.
    • There is an orange ribbon cable that connects the cover to the base, so don't separate the two pieces completely.
    • Remove the single 2 mm screw using a Torx T3 screwdriver.
    • Disconnect the orange cable from the base of the device.
  4. Google Pixelbook Go Right Charging Port Replacement: 步骤 4 中的图像 1,1
    • Insert wisdom here.
  5. Google Pixelbook Go Right Charging Port Replacement, Right Charging Port: 步骤 5 中的图像 1,1
    • Remove the three pink screws from the right charging port using a T3 Torx screwdriver.
  6. Google Pixelbook Go Right Charging Port Replacement: 步骤 6 中的图像 1,2 Google Pixelbook Go Right Charging Port Replacement: 步骤 6 中的图像 2,2
    • Remove the right charging port by picking it up and lifting it from the computer.
结论
Katie Brennan
于03/01/23注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 170
