跳转到主内容
Google Pixelbook Display Replacement
你所需要的
  1. Google Pixelbook Display Replacement, Battery (Back Panel): 步骤 1 中的图像 1,3 Google Pixelbook Display Replacement, Battery (Back Panel): 步骤 1 中的图像 2,3 Google Pixelbook Display Replacement, Battery (Back Panel): 步骤 1 中的图像 3,3
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    After using the spurger to start lifting the rubber like cover at a corner, a two inch wide paint scrapper proved to be an easy way to continue. Using the scrapper at roughly a 30 degree angle (with respect to the laptop rectangle) allowed progressive lifting of the cover. Ripping of the cover tended to occur if only the narrow spurger was used.
    Marvin Stodolsky - 回复
    Please i need to buy the motherboard
    This my email chikaubah33@yahoo.com
    chika ubah - 回复
    The narrow rubber foot at the base of the display is supported by bendable metal. Be careful how evenly you remove it as uneven motions will result in a more bent and harder to re-apply piece.
    Meta Data - 回复
  2. Google Pixelbook Display Replacement: 步骤 2 中的图像 1,2 Google Pixelbook Display Replacement: 步骤 2 中的图像 2,2
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Display Replacement: 步骤 3 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 3 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 3 中的图像 3,3
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    Just a heads up on “Step 3”: (not sure if maybe mine is a newer model since I just got it about a week ago) But there are only 15 of the T5 Screws on mine… Not 17. There are only 2, instead of 4, screws at the top of the picture (located at the hinge) showing the back where they are all circled.
    Jeff Lewis - 回复
    I had the same experience as Jeff.
    Paul Schreiber - 回复
    same, there are only two screws up top, not 4, thus 15 total
    Meta Data - 回复
  4. Google Pixelbook Display Replacement: 步骤 4 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 4 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 4 中的图像 3,3
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Display Replacement: 步骤 5 中的图像 1,2 Google Pixelbook Display Replacement: 步骤 5 中的图像 2,2
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    For me, these were T4 and not T3 screws (everything labelled T3 was a T4 for me).
    Paul Schreiber - 回复
  6. Google Pixelbook Display Replacement: 步骤 6 中的图像 1,2 Google Pixelbook Display Replacement: 步骤 6 中的图像 2,2
    • Remove the small, black casing by using the spudger to lift it up from its place.
    Does anyone know if I can get the cable shown in this image as its own part? It is the only thing wrong with my machine and I don't want to fork out £70 for an entire new battery and cable.
    Mark Huttley - 回复
  7. Google Pixelbook Display Replacement: 步骤 7 中的图像 1,1
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Display Replacement, Display Board: 步骤 8 中的图像 1,1
    • Use an iSclack, or suction cup, to lift up the corner of the display from the case.
  9. Google Pixelbook Display Replacement: 步骤 9 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 9 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 9 中的图像 3,3
    • Insert an opening pick into the gap between the display and case.
    • Repeat this procedure on other side.
  10. Google Pixelbook Display Replacement: 步骤 10 中的图像 1,1
    • Using an opening pick, slowly pry up on the display until it separates.
    • Don't completely remove the display as ribbon cables connect it to the case.
  11. Google Pixelbook Display Replacement: 步骤 11 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 11 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 11 中的图像 3,3
    • Use the pointed end of spudger to flip up the small locking flap on the ZIF connector.
    • Remove the display ribbon cable from the socket.
  12. Google Pixelbook Display Replacement: 步骤 12 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 12 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 12 中的图像 3,3
    • Use the pointed end of a spudger to flip up the small locking flap on the ZIF connector.
    The text is misleading for this step- you're really just peeling back the cushy adhesive and pulling out the ribbon cable. The pictures are accurate.
    Cliff Galloway - 回复
  13. Google Pixelbook Display Replacement: 步骤 13 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 13 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 13 中的图像 3,3
    • Flip the display over and lay it flat on the keyboard.
  14. Google Pixelbook Display Replacement: 步骤 14 中的图像 1,3 Google Pixelbook Display Replacement: 步骤 14 中的图像 2,3 Google Pixelbook Display Replacement: 步骤 14 中的图像 3,3
    • Use a pair of tweezers to grab the clip on the display connector and swing it over to the other side of the socket.
    • Pull on the clip to disconnect the display.
    • Remove the display.
结论
11等其他人完成本指南。
Blake Klein
于01/29/17注册
70,510 声望
创作了50篇指南
9条评论
Where would you find a replacement display?
Carlos Garcia - 回复
Any idea on where to get a display replacement for the Pixelbook?
Nicolas - 回复
Is it necessary to remove the back in order to remove the screen? I cant see any connection between the two?
Thanks
Stevie B - 回复
You remove the back to disconnect the battery.
Sergio B -
any idea how to remove the glass shade on the back panel?
jon - 回复
Is there a way to remove the entire screen assembly portion (lid) and replace it? I have two broken pixelbooks and I’d like to make a working one.
Trevor Standley - 回复
Still waiting for a display replacement. link.
Menoats Untouchable - 回复
Found a full-lid assembly replacement on eBay, but no instructions. Should be easier than this, but I'm not sure without instructions. Any ideas? (Actually rented my life, so a full replacement is really great)
Martin Yonke - 回复
Not very useful when the only replacement screens I can find are culls from dead Pixelbooks on eBay :-(
Paul Ste. Marie - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 34
过去 30 天: 106
总计 10,398
