跳转到主内容
简介
Prereq only! Opening procedure for the Google Pixel XL. Removes midframe.
The Pixel XL’s unreinforced display panel is fragile and is attached to the frame with strong adhesive, making repairs difficult. There is a considerable chance of breaking the display, especially if it already has micro-fractures. Be sure to apply plenty of heat and be extremely careful during the prying stage.
  1. Remove the following screws that secure the midframe to the back:
    • Remove the following screws that secure the midframe to the back:
    • Seven black 4 mm T5 screws
    • Two silver 3 mm T5 screws
  2. The midframe is held tightly in place by plastic clips which push into the edge of the back case.
    • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
  3. Find the small notch in the bottom left corner of the frame and insert an opening pick. Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there. Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
    • Find the small notch in the bottom left corner of the frame and insert an opening pick.
    • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
  4. Insert a separate opening pick into the right edge of the phone, near the bottom. Slowly push the pick upwards along the seam until the first clip pops free. Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Insert a separate opening pick into the right edge of the phone, near the bottom.
    • Slowly push the pick upwards along the seam until the first clip pops free.
    • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
  5. Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip. You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
    • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
    • You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
    • Slowly slide the pick past the clip to disengage it from the frame.
    • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
  6. Grasp the right edge of the midframe by the corners and slowly hinge the edge up. When the left edge feels loose, stop hinging and lift the midframe upwards. Remove the midframe.
    • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
    • When the left edge feels loose, stop hinging and lift the midframe upwards.
    • Remove the midframe.
    • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
结论
Arthur Shi
于2018年01月03日注册
173,054 信誉积分
创作了428篇指南
团队
iFixit iFixit 的会员
Community
138 名成员
创作了16,993篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 81
