跳转到主内容
加入维修社区 - 创建账户
Google Pixel Slate Speaker Replacement
你所需要的
  1. Google Pixel Slate Speaker Replacement, Screen: 步骤 1 中的图像 1,3 Google Pixel Slate Speaker Replacement, Screen: 步骤 1 中的图像 2,3 Google Pixel Slate Speaker Replacement, Screen: 步骤 1 中的图像 3,3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body. The screen is held down by adhesive, you will need to use the iOpener or a heat gun/ hairdryer to soften it. Failure to do this will result in a broken screen.
    • Use the suction cup to remove the screen from the body of the device.
    添加评论
  2. Google Pixel Slate Speaker Replacement: 步骤 2 中的图像 1,3 Google Pixel Slate Speaker Replacement: 步骤 2 中的图像 2,3 Google Pixel Slate Speaker Replacement: 步骤 2 中的图像 3,3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
    添加评论
  3. Google Pixel Slate Speaker Replacement, Speaker: 步骤 3 中的图像 1,3 Google Pixel Slate Speaker Replacement, Speaker: 步骤 3 中的图像 2,3 Google Pixel Slate Speaker Replacement, Speaker: 步骤 3 中的图像 3,3
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
    询问修复机器人
    添加评论
  4. Google Pixel Slate Speaker Replacement: 步骤 4 中的图像 1,1
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
    询问修复机器人
    添加评论
  5. Google Pixel Slate Speaker Replacement: 步骤 5 中的图像 1,2 Google Pixel Slate Speaker Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
    询问修复机器人
    添加评论
  6. Google Pixel Slate Speaker Replacement: 步骤 6 中的图像 1,2 Google Pixel Slate Speaker Replacement: 步骤 6 中的图像 2,2
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
    询问修复机器人
    添加评论
  7. Google Pixel Slate Speaker Replacement: 步骤 7 中的图像 1,2 Google Pixel Slate Speaker Replacement: 步骤 7 中的图像 2,2
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
    询问修复机器人
    添加评论
  8. Google Pixel Slate Speaker Replacement: 步骤 8 中的图像 1,3 Google Pixel Slate Speaker Replacement: 步骤 8 中的图像 2,3 Google Pixel Slate Speaker Replacement: 步骤 8 中的图像 3,3
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
    询问修复机器人
    添加评论
  9. Google Pixel Slate Speaker Replacement: 步骤 9 中的图像 1,1
    • You can now remove the speaker from the device.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G5
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 19
总计 1,260
