简介
This guide walks you through the process of removing a speaker from a Google Pixel Slate. Before attempting to proceed with this guide, a user should understand how to use a screwdriver. In order to replace the speaker and reassemble the device, follow the steps in reverse.
你所需要的
Orient the Google Pixel Slate so that the screen is facing upwards.
Use the iFixit opening tool to separate screen from main body.
Use the suction cup to remove the screen from the body of the device.
Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
Remove the thin metal plate from the device.
3等其他人完成本指南。
