跳转到主内容
Google Pixel Slate Screen Replacement
你所需要的
  1. Google Pixel Slate Screen Replacement, Screen: 步骤 1 中的图像 1,3 Google Pixel Slate Screen Replacement, Screen: 步骤 1 中的图像 2,3 Google Pixel Slate Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Screen Replacement: 步骤 2 中的图像 1,3 Google Pixel Slate Screen Replacement: 步骤 2 中的图像 2,3 Google Pixel Slate Screen Replacement: 步骤 2 中的图像 3,3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
结论
5等其他人完成本指南。
Spencer Alonge
于04/18/19注册
669 声望
创作了5篇指南
团队
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G5
4 名成员
创作了5篇指南
13指南评论
Where did you source the replacement screen? Can we get a link added to the parts list?
Brandon Price - 回复
Anyone know where to source the replacement screen? Any help would be greatly appreciated.
Brandon Price - 回复
Yeah, I could use the replacement source as well. Thanks.
Benjamin Reese - 回复
me too! the resource replacement link plz!!
gabriela urquidi - 回复
Is the screen held down with adhesive or does it have any clips? Also, does anyone know where I could source any Pixel Slate parts?
Kevin Freyre - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 48
总计 5,506
