跳转到主内容
Google Pixel Slate Motherboard Replacement
你所需要的
  1. Google Pixel Slate Motherboard Replacement, Screen: 步骤 1 中的图像 1,3 Google Pixel Slate Motherboard Replacement, Screen: 步骤 1 中的图像 2,3 Google Pixel Slate Motherboard Replacement, Screen: 步骤 1 中的图像 3,3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Motherboard Replacement: 步骤 2 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 2 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 2 中的图像 3,3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,3 Google Pixel Slate Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,3 Google Pixel Slate Motherboard Replacement, Motherboard: 步骤 3 中的图像 3,3
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: 步骤 4 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 4 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: 步骤 5 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 5 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: 步骤 6 中的图像 1,2 Google Pixel Slate Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: 步骤 7 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 7 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
  8. Google Pixel Slate Motherboard Replacement: 步骤 8 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 8 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 8 中的图像 3,3
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: 步骤 9 中的图像 1,3 Google Pixel Slate Motherboard Replacement: 步骤 9 中的图像 2,3 Google Pixel Slate Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use the iFixit opening tool to remove the motherboard from the device.
结论
3等其他人完成本指南。
Spencer Alonge
于04/18/19注册
648 声望
创作了5篇指南
团队
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G5
4 名成员
创作了5篇指南
一条评论
Very helpful, nice and clear steps.
Eddie Lundberg - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 64
总计 3,389
