简介
Use this guide to remove and replace the front-facing camera of your Google Pixel Slate.
你所需要的
Orient the Google Pixel Slate so that the screen is facing upwards.
Use the iFixit opening tool to separate screen from main body. The screen is held down by adhesive, you will need to use the iOpener or a heat gun/ hairdryer to soften it. Failure to do this will result in a broken screen.
Use the suction cup to remove the screen from the body of the device.
Once removed, place the screen face down.
Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
2等其他人完成本指南。
1指南评论
Do you offer the cable that runs from the camera to the tablet motherboard or the front facing camera with cable?
Heidi Hose - 回复 分享
