跳转到主内容
加入维修社区 - 创建账户
Google Pixel Slate Front-Facing Camera Replacement
你所需要的
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: 步骤 1 中的图像 1,3 Google Pixel Slate Front-Facing Camera Replacement, Screen: 步骤 1 中的图像 2,3 Google Pixel Slate Front-Facing Camera Replacement, Screen: 步骤 1 中的图像 3,3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body. The screen is held down by adhesive, you will need to use the iOpener or a heat gun/ hairdryer to soften it. Failure to do this will result in a broken screen.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: 步骤 2 中的图像 1,3 Google Pixel Slate Front-Facing Camera Replacement: 步骤 2 中的图像 2,3 Google Pixel Slate Front-Facing Camera Replacement: 步骤 2 中的图像 3,3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 步骤 3 中的图像 1,3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 步骤 3 中的图像 2,3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: 步骤 3 中的图像 3,3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: 步骤 4 中的图像 1,3 Google Pixel Slate Front-Facing Camera Replacement: 步骤 4 中的图像 2,3 Google Pixel Slate Front-Facing Camera Replacement: 步骤 4 中的图像 3,3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: 步骤 5 中的图像 1,2 Google Pixel Slate Front-Facing Camera Replacement: 步骤 5 中的图像 2,2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: 步骤 6 中的图像 1,2 Google Pixel Slate Front-Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
结论
2等其他人完成本指南。
Spencer Alonge
于04/18/19注册
678 声望
创作了5篇指南
团队
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 的会员
CPSU-MANESS-S19S2G5
4 名成员
创作了5篇指南
1指南评论
Do you offer the cable that runs from the camera to the tablet motherboard or the front facing camera with cable?
Heidi Hose - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 1,025
