跳转到主内容
Google Pixel Display Replacement
你所需要的
  1. Google Pixel Display Replacement, Display: 步骤 1 中的图像 1,1
    • Turn off the device.
    • Prepare an iOpener to heat the edges of the display and soften the adhesive underneath. Alternatively, you may use a heat gun or a hair dryer.
    • The surfaces near the speaker and microphone (top and bottom respectively) have larger adhesive sections. These areas may require slightly longer heat exposure. The display should be heated until it's slightly too hot to touch, for roughly two minutes.
  2. Google Pixel Display Replacement: 步骤 2 中的图像 1,3 Google Pixel Display Replacement: 步骤 2 中的图像 2,3 Google Pixel Display Replacement: 步骤 2 中的图像 3,3
    • In the following steps, you will separate the display panel by slicing though the adhesive bonding the display to the Pixel's chassis.
    • For reference, the back of the display panel is shown at left. Note the narrow clearance between the side of the display unit and the OLED panel.
    • Inserting an opening tool deeper than 1.5 mm into the sides of the device, or 9 mm into the top and bottom can permanently damage the display.
  3. Google Pixel Display Replacement: 步骤 3 中的图像 1,2 Google Pixel Display Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Suction Handle
    $2.99
    购买
    • Use a suction handle to pull up on the display and create a slight gap between the display and the phone's chassis.
    • If your display is cracked, cover it with packing tape to help the suction cup adhere and prevent glass shards from popping loose.
  4. Google Pixel Display Replacement: 步骤 4 中的图像 1,3 Google Pixel Display Replacement: 步骤 4 中的图像 2,3 Google Pixel Display Replacement: 步骤 4 中的图像 3,3
    • Insert an opening pick or a playing card into the gap between the chassis and the display assembly.
    • Begin to slide the opening pick around the edge of the display, cutting through the adhesive that secures it.
    • The display panel is fragile. If you plan to re-use your display, take care to insert your tool only as far as necessary to separate the adhesive. Inserting the tool any further can damage the OLED panel under the glass.
  5. Google Pixel Display Replacement: 步骤 5 中的图像 1,3 Google Pixel Display Replacement: 步骤 5 中的图像 2,3 Google Pixel Display Replacement: 步骤 5 中的图像 3,3
    • Continue carefully separating the adhesive around the rest of the device.
    • Take extra care with the side bezels, which are only 1.5 mm deep.
  6. Google Pixel Display Replacement: 步骤 6 中的图像 1,3 Google Pixel Display Replacement: 步骤 6 中的图像 2,3 Google Pixel Display Replacement: 步骤 6 中的图像 3,3
    • With the adhesive cut, slowly lift the display up from the top (the side with the speaker-grille cutout), carefully flip it over vertically toward the bottom of the device, and rest it on its face, as shown.
    • Do not attempt to completely remove the display yet, as it is still connected by a fragile ribbon cable. Be careful to not to strain the cable while positioning the display.
  7. Google Pixel Display Replacement: 步骤 7 中的图像 1,1
    • Use a T5 Torx driver to remove the two black 3.5 mm T5 screws securing the display cable connector bracket.
  8. Google Pixel Display Replacement: 步骤 8 中的图像 1,1
    • Use tweezers to remove the bracket that holds the display connector in place.
  9. Google Pixel Display Replacement: 步骤 9 中的图像 1,1
  10. Google Pixel Display Replacement: 步骤 10 中的图像 1,1
    • Remove the display.
    • Some replacement displays do not come with an earpiece speaker grille. If your replacement screen doesn't have one, be sure to transfer the grille from your old display to the new one.
    • During reassembly, pause here to replace the display adhesive.
结论
59等其他人完成本指南。
Taylor Dixon
于06/26/18注册
67,033 声望
创作了94篇指南
19条评论
hey, is the replacement screen meant to have adhesive on it already?
noisycrow - 回复
No, it does not. Just replaced my screen. The residual adhesive is good enough to keep it on temporarily, but I’m going to a local repair shop to grab something better.
Vitaliy Isikov -
It’s also best to, if you haven’t already, look at your replacement part to get a feeling of how far you can go with the guitar pick or pry tool. It’s around 1/16th of an inch on the sides so you don’t want to go too far in and damage the display
Jason Stewart - 回复
Honestly, this felt easier than what the guide advised, definitely invest in the ifixit opening kit, made this a breeze. Hardest part was just scrapping the leftover residue off after removing the cracked screen.
Craig Beery II - 回复
You can use any adhesive for screen replacements for this screen. I personally used a double-sided tape 2 mm wide. The replacement screen does not usually come with the fabric covering the phone speakers, so make sure to transfer it from your old screen.
Mingye Wang - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 99
过去 30 天: 394
总计 96,272
