跳转到主内容
Google Pixel C Speaker Replacement
你所需要的
  1. Google Pixel C Speaker Replacement, Screen: 步骤 1 中的图像 1,1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Speaker Replacement: 步骤 2 中的图像 1,2 Google Pixel C Speaker Replacement: 步骤 2 中的图像 2,2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Speaker Replacement: 步骤 3 中的图像 1,2 Google Pixel C Speaker Replacement: 步骤 3 中的图像 2,2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Speaker Replacement: 步骤 4 中的图像 1,2 Google Pixel C Speaker Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
  5. Google Pixel C Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Locate the thin black speakers along the right and left sides of the tablet.
    • The longer speaker is secured by two different types of screws, while the shorter one is secured by two of the same type of screw.
  6. Google Pixel C Speaker Replacement: 步骤 6 中的图像 1,1
    • Use the Phillips #000 screwdriver to remove the three 4.2mm screws
    • Use the same screwdriver to remove the 2.5mm screw as well.
  7. Google Pixel C Speaker Replacement: 步骤 7 中的图像 1,3 Google Pixel C Speaker Replacement: 步骤 7 中的图像 2,3 Google Pixel C Speaker Replacement: 步骤 7 中的图像 3,3
    • Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
    • Locate and detach the third cable cap that is attached to the longer speaker.
    • The third cable runs along the upper edge of the device, and is secured down with adhesive.
  8. Google Pixel C Speaker Replacement: 步骤 8 中的图像 1,1
    • Slide both speakers out from the edges of the device.
  9. Google Pixel C Speaker Replacement: 步骤 9 中的图像 1,3 Google Pixel C Speaker Replacement: 步骤 9 中的图像 2,3 Google Pixel C Speaker Replacement: 步骤 9 中的图像 3,3
    • Locate the red and black twisted wires.
    • Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
结论
Isabelle Tang
于04/26/17注册
225 声望
创作了2篇指南
团队
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 866
