跳转到主内容
加入维修社区 - 创建账户
Google Pixel C Screen Replacement
你所需要的
  1. Google Pixel C Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Screen Replacement: 步骤 2 中的图像 1,2 Google Pixel C Screen Replacement: 步骤 2 中的图像 2,2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Screen Replacement: 步骤 3 中的图像 1,2 Google Pixel C Screen Replacement: 步骤 3 中的图像 2,2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Screen Replacement: 步骤 4 中的图像 1,2 Google Pixel C Screen Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
结论
9等其他人完成本指南。
团队
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G4
4 名成员
创作了11篇指南
28指南评论
Where can a replacement screen be located?
Ronnie Williams - 回复 分享
Where can i buy a spare screen for this tablet?
Luigi Abbinante - 回复 分享
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - 回复 分享
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - 回复 分享
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Luigi Abbinante - 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 42
过去 30 天: 162
总计 19,333
