跳转到主内容
Google Pixel C Keyboard Replacement
你所需要的
  1. Google Pixel C Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Heat the black plastic strip on the front lower edge of the keyboard with an iOpener to weaken the adhesive holding it down.
    • When reattaching the plastic strip, apply adhesive to ensure that the strip will stay securely in place.
  2. Google Pixel C Keyboard Replacement: 步骤 2 中的图像 1,2 Google Pixel C Keyboard Replacement: 步骤 2 中的图像 2,2
    • Use a medium plastic opening tool to lift the black plastic strip from the lower edge of the keyboard.
  3. Google Pixel C Keyboard Replacement: 步骤 3 中的图像 1,2 Google Pixel C Keyboard Replacement: 步骤 3 中的图像 2,2
    • Locate the four 3.1mm Phillips #000 screws that hold the keyboard to the back plate.
    • Using the Phillips #000 Screwdriver, remove the screws from the keyboard.
    • The screws are reverse threaded, so turn them clockwise to remove them.
  4. Google Pixel C Keyboard Replacement: 步骤 4 中的图像 1,1
    • Orient the keyboard so that the side with the keys is facedown on the table.
    • Use either an iFixit iOpener OR a heat gun to melt the adhesive that holds the top half of the keyboard to the bottom.
    • When using a heat gun for removal, only heat the backside of the keyboard to avoid warping the keys.
  5. Google Pixel C Keyboard Replacement: 步骤 5 中的图像 1,3 Google Pixel C Keyboard Replacement: 步骤 5 中的图像 2,3 Google Pixel C Keyboard Replacement: 步骤 5 中的图像 3,3
    • Using a plastic or nylon spudger, pry the two halves of the keyboard apart.
    • If the plastic spudger doesn’t work, it is okay to use a metal spudger, but take care not to scratch or damage the device.
    • Be mindful of the amount of force applied to avoid snapping the keyboard.
    • It will be necessary to use adhesive to ensure that the keyboard is securely in place during reassembly.
结论
2等其他人完成本指南。
Makenzie Kamei
于04/26/17注册
137 声望
撰写一个指南
团队
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S21G4
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 1,943
