跳转到主内容
Google Pixel 9 Pro XL Wireless Charging Assembly Replacement
你所需要的
  1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 步骤 2 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 步骤 2 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: 步骤 2 中的图像 3,3
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: 步骤 3 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: 步骤 3 中的图像 2,2
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 3,3
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: 步骤 5 中的图像 3,3
    • Slide your opening pick along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 6 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 6 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 6 中的图像 3,3
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 7 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 7 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 7 中的图像 3,3
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 步骤 8 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 步骤 8 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: 步骤 8 中的图像 3,3
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 步骤 9 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 步骤 9 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 10 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 10 中的图像 2,2
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 步骤 11 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 步骤 11 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: 步骤 11 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the rear cover: 步骤 12 中的图像 1,1
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 步骤 13 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 步骤 13 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: 步骤 13 中的图像 3,3
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 步骤 14 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: 步骤 14 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 15 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 15 中的图像 2,2
    • Use tweezers or your fingers to remove the cover.
  16. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: 步骤 16 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: 步骤 16 中的图像 2,2
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 17 中的图像 1,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 17 中的图像 2,3 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: 步骤 17 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: 步骤 18 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: 步骤 18 中的图像 2,2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 步骤 19 中的图像 1,2 Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: 步骤 19 中的图像 2,2
    • Remove the wireless charging assembly.
结论
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
于09/14/22注册
149,442 声望
创作了995篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,612篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 53
总计 869
