跳转到主内容
加入维修社区 - 创建账户
Google Pixel 6 Camera Glass Panel Replacement
你所需要的
  1. Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: 步骤 1 中的图像 1,2 Google Pixel 6 Camera Glass Panel Replacement, Camera Glass Panel: 步骤 1 中的图像 2,2
    • Use the wet wipe included in your kit to clean the rear camera glass panel.
    • Dry off the rear camera glass panel with the dry wipe.
  2. Google Pixel 6 Camera Glass Panel Replacement: 步骤 2 中的图像 1,2 Google Pixel 6 Camera Glass Panel Replacement: 步骤 2 中的图像 2,2
    • Carefully cut around the edges of the phone's rear glass panel using an X-Acto knife.
    • Caution: Hazardous situation which involves a sharp utensil and glass fragments.
  3. Google Pixel 6 Camera Glass Panel Replacement: 步骤 3 中的图像 1,2 Google Pixel 6 Camera Glass Panel Replacement: 步骤 3 中的图像 2,2
    • Using the tweezers, begin chipping and tweezing away at the cracked region.
    • Caution: Shards and shrapnel can splinter off of the panel.
    • Keep some masking tape near to be able to pick up shrapnel without injuring yourself.
  4. Google Pixel 6 Camera Glass Panel Replacement: 步骤 4 中的图像 1,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 4 中的图像 2,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 4 中的图像 3,3
    • Use the metal spudger to remove the larger pieces of the glass to expose the layer underneath.
    • Caution: Hastily removing sharp fragments pieces could result in injury.
  5. Google Pixel 6 Camera Glass Panel Replacement: 步骤 5 中的图像 1,2 Google Pixel 6 Camera Glass Panel Replacement: 步骤 5 中的图像 2,2
    • Use the opening tool to remove excess glue leftover from the old glass panel.
    • Perform this step only when all glass has been removed from the camera area.
  6. Google Pixel 6 Camera Glass Panel Replacement: 步骤 6 中的图像 1,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 6 中的图像 2,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 6 中的图像 3,3
    • Take a piece of masking tape about 3 inches wide.
    • Gently press the masking tape (sticky side down) onto the rear camera lens and lift, removing the glass debris.
    • Repeat until most of the glass debris is removed.
  7. Google Pixel 6 Camera Glass Panel Replacement: 步骤 7 中的图像 1,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 7 中的图像 2,3 Google Pixel 6 Camera Glass Panel Replacement: 步骤 7 中的图像 3,3
    • Align the glass panel replacement with the exposed camera area.
    • Press the glass panel firmly into the camera area.
    • Do not press too hard to avoid cracking glass from excess pressure.
    • Let the glass panel adhesive dry for approximately two hours before using the phone.
终点
另外一个人完成了本指南。
Aliyah Sims
于02/19/25注册
154 声望
撰写一个指南
团队
UC Davis, Team 1-6, Andersen Winter 2025 UC Davis, Team 1-6, Andersen Winter 2025 的会员
UCD-ANDERSEN-W25S1G6
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 26
过去 30 天: 124
总计 1,308
