跳转到主内容
Google Pixel 5a Motherboard Replacement
你所需要的
    • Insert a SIM card eject tool into the small hole on the right side edge of the frame.
    • A standard SIM card eject tool may be too wide for the job. Don't force the tool in—use a small paperclip, or a properly sized tool, like the SIM eject bit.
    • Press firmly until you feel the SIM card tray pop out.
    • Remove the SIM card tray from the phone.
  1. Google Pixel 5a Motherboard Replacement, Precautionary notes: 步骤 2 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Precautionary notes: 步骤 2 中的图像 2,2
    • Be sure to turn off your device before you begin the repair.
    • You'll need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
  2. Google Pixel 5a Motherboard Replacement, Heat the right edge of the screen: 步骤 3 中的图像 1,1
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • Depending on the strength of your device's adhesive, you may need to reapply the iOpener multiple times in order to weaken it enough.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 5a Motherboard Replacement, Bezel removal note: 步骤 4 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Bezel removal note: 步骤 4 中的图像 2,2
    • To remove the screen, you'll need to insert opening picks in between the black clips that secure the bezel to the midframe.
    • Note the optimal points of entry before proceeding.
  4. Google Pixel 5a Motherboard Replacement, Create a gap between the bezel and midframe: 步骤 5 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Create a gap between the bezel and midframe: 步骤 5 中的图像 2,2
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force until a small gap forms between the bezel and midframe.
  5. Google Pixel 5a Motherboard Replacement, Insert an opening pick: 步骤 6 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Insert an opening pick: 步骤 6 中的图像 2,2
    • The bezel is connected to the midframe by a series of plastic clips which can be detached by inserting an opening pick at points all along the seam.
    • Insert the tip of an opening pick into the bezel seam about 4-5 cm from the bottom of the phone.
  6. Google Pixel 5a Motherboard Replacement: 步骤 7 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 7 中的图像 2,2
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm from the top of the phone.
  7. Google Pixel 5a Motherboard Replacement: 步骤 8 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 8 中的图像 2,2
    • Insert the tip of an opening pick into the bezel seam at the top of the phone.
    • If this step proves difficult, slide the pick along the top right corner of the phone until there is enough of a gap at the top for the opening pick.
  8. Google Pixel 5a Motherboard Replacement: 步骤 9 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 9 中的图像 2,2
    • Insert the tip of an opening pick into the bezel seam at the bottom of the phone.
    • If this step proves difficult, slide the pick along bottom right corner of the phone until there is enough of a gap at the bottom for the opening pick.
  9. Google Pixel 5a Motherboard Replacement: 步骤 10 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 10 中的图像 2,2
    • Insert the tip of an opening pick into the bezel seam on the left side of the phone, about 2 cm from the bottom of the phone.
  10. Google Pixel 5a Motherboard Replacement: 步骤 11 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 11 中的图像 2,2
    • Insert the tip of an opening pick into the bezel seam about 3-4 cm below the front-facing camera.
  11. Google Pixel 5a Motherboard Replacement: 步骤 12 中的图像 1,3 Google Pixel 5a Motherboard Replacement: 步骤 12 中的图像 2,3 Google Pixel 5a Motherboard Replacement: 步骤 12 中的图像 3,3
    • Be sure to detach all the clips. Slice through any remaining adhesive with an opening pick.
    • Open the device from the right side like a book.
    • Use a T3 Torx driver to remove the 4.6 mm-long screw securing the screen connector bracket.
  12. Google Pixel 5a Motherboard Replacement, Remove the connector bracket: 步骤 14 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Remove the connector bracket: 步骤 14 中的图像 2,2
    • Use a pair of tweezers to remove the screen connector bracket.
  13. Google Pixel 5a Motherboard Replacement, Remove the screen: 步骤 15 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Remove the screen: 步骤 15 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  14. Google Pixel 5a Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the screen from the phone.
    • If you are using a custom-cut adhesive, follow this guide to correctly apply new screen adhesive.
    • If you are using Tesa tape to reattach the screen, follow this guide.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  15. Google Pixel 5a Motherboard Replacement, Remove the screws: 步骤 17 中的图像 1,1
    • Use a T3 Torx driver to remove six of the screws securing the midframe to the motherboard:
    • Four 4.6 mm screws
    • One 4.0 mm screw
    • One 2.0 mm screw
    • Since a few of these screws have different lengths, keep track of each screw and be sure to reinstall them in their proper places.
  16. Google Pixel 5a Motherboard Replacement, Remove the black plastic cover: 步骤 18 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Remove the black plastic cover: 步骤 18 中的图像 2,2
    • Use the pointed end of a spudger to pry up on the black plastic cover at the bottom left of the phone.
  17. Google Pixel 5a Motherboard Replacement: 步骤 19 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 19 中的图像 2,2
    • Slide the pointed end of the spudger left until the plastic cover is completely separated from the midframe.
    • Remove the plastic cover from the midframe.
  18. Google Pixel 5a Motherboard Replacement: 步骤 20 中的图像 1,3 Google Pixel 5a Motherboard Replacement: 步骤 20 中的图像 2,3 Google Pixel 5a Motherboard Replacement: 步骤 20 中的图像 3,3
    • Use a pair of tweezers to slightly peel back the tape concealing the two screws securing the charging port bracket.
  19. Google Pixel 5a Motherboard Replacement, Remove the remaining screws: 步骤 21 中的图像 1,1
    • Use a T3 Torx driver to remove the remaining four screws securing the midframe to the motherboard:
    • Three 4.6 mm screws
    • One 4.0 mm screw
  20. Google Pixel 5a Motherboard Replacement: 步骤 22 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 22 中的图像 2,2
    • Use a spudger or a pair of tweezers to peel back the tape securing the charging port bracket to the speaker assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  21. Google Pixel 5a Motherboard Replacement: 步骤 23 中的图像 1,3 Google Pixel 5a Motherboard Replacement: 步骤 23 中的图像 2,3 Google Pixel 5a Motherboard Replacement: 步骤 23 中的图像 3,3
    • Use a blunt pair of tweezers, or your fingers, to carefully peel back the graphite sheet covering the battery.
    • Be careful not to accidentally puncture or otherwise damage the battery when gripping the graphite sheet.
  22. Google Pixel 5a Motherboard Replacement, Detach the midframe: 步骤 24 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Detach the midframe: 步骤 24 中的图像 2,2
    • Insert the pointed end of a spudger under the top right corner of the midframe.
    • There is a black plastic clip at the top of the midframe that secures it to the top of the frame. To detach it, use the spudger to pull the midframe down and then pry up.
  23. Google Pixel 5a Motherboard Replacement, Remove the midframe: 步骤 25 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Remove the midframe: 步骤 25 中的图像 2,2
    • Remove the midframe.
  24. Google Pixel 5a Motherboard Replacement, Replace the plastic bits: 步骤 26 中的图像 1,3 Google Pixel 5a Motherboard Replacement, Replace the plastic bits: 步骤 26 中的图像 2,3 Google Pixel 5a Motherboard Replacement, Replace the plastic bits: 步骤 26 中的图像 3,3
    • There are two small plastic bits that help hold the midframe in place. Take care not to misplace them, as without the midframe to hold them in place, they are very easy to lose.
    • Be sure to place these back into their respective corners before replacing the midframe when reassembling your device.
  25. Google Pixel 5a Motherboard Replacement, Disconnect the battery: 步骤 27 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Disconnect the battery: 步骤 27 中的图像 2,2
    • Use the flat end of a spudger to pry up on the battery connector to disconnect it.
  26. Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: 步骤 28 中的图像 1,3 Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: 步骤 28 中的图像 2,3 Google Pixel 5a Motherboard Replacement, Remove the 16 MP Ultrawide camera: 步骤 28 中的图像 3,3
    • Use the flat end of a spudger to pry up on the 16 MP Ultrawide camera's connector to disconnect it.
    • Remove the 16 MP Ultrawide camera.
  27. Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: 步骤 29 中的图像 1,3 Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: 步骤 29 中的图像 2,3 Google Pixel 5a Motherboard Replacement, Remove the 12.2 MP Wide-Angle camera: 步骤 29 中的图像 3,3
    • Use the flat end of a spudger to pry up on the 12.2 MP Wide-Angle camera's connector to disconnect it.
    • Remove the 12.2 MP Wide-Angle camera.
  28. Google Pixel 5a Motherboard Replacement, Disconnect the headphone jack: 步骤 30 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Disconnect the headphone jack: 步骤 30 中的图像 2,2
    • Use the pointed end of a spudger to pry up on the headphone jack connector to disconnect it.
  29. Google Pixel 5a Motherboard Replacement, Remove the headphone jack: 步骤 31 中的图像 1,3 Google Pixel 5a Motherboard Replacement, Remove the headphone jack: 步骤 31 中的图像 2,3 Google Pixel 5a Motherboard Replacement, Remove the headphone jack: 步骤 31 中的图像 3,3
    • Use the flat end of a spudger to pry up on the headphone to pop it out of its socket.
    • Remove the headphone jack.
  30. Google Pixel 5a Motherboard Replacement, Disconnect the fingerprint sensor cable: 步骤 32 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Disconnect the fingerprint sensor cable: 步骤 32 中的图像 2,2
    • Use the flat end of a spudger to pry up on the fingerprint sensor connector to disconnect it.
  31. Google Pixel 5a Motherboard Replacement, Disconnect the camera flash cable: 步骤 33 中的图像 1,2 Google Pixel 5a Motherboard Replacement, Disconnect the camera flash cable: 步骤 33 中的图像 2,2
    • Use the flat end of a spudger to pry up on the camera flash connector to disconnect it.
  32. Google Pixel 5a Motherboard Replacement, Remove the motherboard screws: 步骤 34 中的图像 1,1
    • Use a T3 Torx driver to remove the three 2.9 mm screws securing the motherboard to the frame.
  33. Google Pixel 5a Motherboard Replacement: 步骤 35 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 35 中的图像 2,2
    • Insert the flat end of a spudger under the top right corner of the motherboard to lift it from the frame.
    • The SIM card tray also secures the motherboard to the frame, so double-check that it has been removed before this step.
  34. Google Pixel 5a Motherboard Replacement: 步骤 36 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 36 中的图像 2,2
    • Insert the flat end of a spudger under the top left corner of the motherboard to lift it from the frame.
  35. Google Pixel 5a Motherboard Replacement: 步骤 37 中的图像 1,2 Google Pixel 5a Motherboard Replacement: 步骤 37 中的图像 2,2
    • Insert the pointed end of a spudger under the the screw slot to the top right of the speaker assembly to dislodge it from the frame.
    • Be careful not to deform the battery when prying at the speaker assembly.
  36. Google Pixel 5a Motherboard Replacement, Remove the motherboard: 步骤 38 中的图像 1,1
    • Remove the motherboard and speaker assembly.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 5a Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
2等其他人完成本指南。
Clay Kim
于02/16/21注册
7,469 声望
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 106
过去 30 天: 461
总计 5,187
