跳转到主内容
Google Pixel 4 XL Soli Motion Sensor Replacement
你所需要的
  1. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the SIM card tray: 步骤 1 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the SIM card tray: 步骤 1 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the SIM card tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 XL Soli Motion Sensor Replacement, Heat the back panel glass: 步骤 2 中的图像 1,1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 XL Soli Motion Sensor Replacement, Apply a suction cup: 步骤 3 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Apply a suction cup: 步骤 3 中的图像 2,2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 XL Soli Motion Sensor Replacement, Insert an opening pick: 步骤 4 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Insert an opening pick: 步骤 4 中的图像 2,2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 XL Soli Motion Sensor Replacement, Begin to slice the adhesive: 步骤 5 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Begin to slice the adhesive: 步骤 5 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Begin to slice the adhesive: 步骤 5 中的图像 3,3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 XL Soli Motion Sensor Replacement, Slice the lefthand-side adhesive: 步骤 6 中的图像 1,1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 7 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 7 中的图像 2,2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 8 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 XL Soli Motion Sensor Replacement, Slice righthand-side adhesive: 步骤 9 中的图像 1,1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 10 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 10 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 10 中的图像 3,3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 XL Soli Motion Sensor Replacement, Slice the top-side adhesive: 步骤 11 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Slice the top-side adhesive: 步骤 11 中的图像 2,2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 XL Soli Motion Sensor Replacement, Lift up the back panel: 步骤 12 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Lift up the back panel: 步骤 12 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Lift up the back panel: 步骤 12 中的图像 3,3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 13 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 13 中的图像 2,2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the battery: 步骤 14 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove the four T3 Torx screws securing the battery connector shield:
    • One 1.8 mm screw
    • One 4.1 mm screw
    • One 4.4 mm shouldered screw
    • One 4.0 mm shouldered screw
  15. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 15 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 15 中的图像 2,2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 16 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 16 中的图像 2,2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 17 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 17 中的图像 2,2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the back panel connector: 步骤 18 中的图像 1,1
    • Use a T3 Torx driver to remove the two 4.1 mm screws securing the back panel connector cover.
  19. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 19 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 19 中的图像 2,2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 20 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 20 中的图像 2,2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the back panel: 步骤 21 中的图像 1,1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the camera connector covers: 步骤 22 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the camera connector covers: 步骤 22 中的图像 2,2
    • Gently pry back the battery adhesive pull tab to allow easier access to the screws underneath it.
  23. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 23 中的图像 1,1
    • Remove the three T3 Torx screws securing the rear-facing camera connector cover:
    • One 2.7 mm screw
    • One 4.1 mm screw
    • One 4.2 mm screw
  24. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 24 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 24 中的图像 2,2
    • Use a pair of tweezers to remove the rear-facing camera connector cover.
  25. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 25 中的图像 1,1
    • Remove the three T3 Torx screws securing the front-facing camera connector cover:
    • One 4.1 mm screw
    • One 4.1 mm shouldered screw
  26. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 26 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 26 中的图像 2,2
    • Use a pair of tweezers to remove the front-facing camera connector cover.
  27. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the camera and sensor connectors: 步骤 27 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the camera and sensor connectors: 步骤 27 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the camera and sensor connectors: 步骤 27 中的图像 3,3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  28. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 28 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 28 中的图像 2,2
    • Disconnect the additional sensor connector.
    • This cable is secured to the phone with some light adhesive.
  29. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the front camera and sensor assembly: 步骤 29 中的图像 1,1
    • Remove the three T3 Torx screws securing the front camera and sensor assembly:
    • Two 2.7 mm screws
    • One 3.1 mm screw
  30. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 30 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 30 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 30 中的图像 3,3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  31. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the screws securing the display connector cover: 步骤 31 中的图像 1,1
    • Use a T3 Torx driver to remove the four 3.5 mm screws securing the display connector cover.
  32. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the display connector cover: 步骤 32 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the display connector cover: 步骤 32 中的图像 2,2
    • Use a pair of tweezers to remove the display connector cover.
  33. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the display connector: 步骤 33 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the display connector: 步骤 33 中的图像 2,2
    • Use the flat end of a spudger to disconnect the display connector from the motherboard.
  34. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the motherboard screw: 步骤 34 中的图像 1,1
    • Use a T3 Torx driver to remove the 2.7 mm screw securing the motherboard to the frame.
  35. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the motherboard press connectors: 步骤 35 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the motherboard press connectors: 步骤 35 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the motherboard press connectors: 步骤 35 中的图像 3,3
    • Use the pointed end of a spudger to disconnect the side buttons connector from the motherboard.
    • Disconnect the two rear-facing camera connectors from the motherboard.
  36. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 36 中的图像 1,1
    • Disconnect the earpiece speaker connector from the motherboard.
  37. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 37 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 37 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 37 中的图像 3,3
    • Disconnect the two grip sensor connectors from the motherboard.
    • Disconnect the charge port connector from the motherboard.
  38. Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the antennas: 步骤 38 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the antennas: 步骤 38 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement, Disconnect the antennas: 步骤 38 中的图像 3,3
    • Use the pointed end of a spudger and pry up gently to unclip the top antenna connector from the motherboard.
    • Disconnect the bottom antenna connector.
  39. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the motherboard: 步骤 39 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the motherboard: 步骤 39 中的图像 2,2
    • Using a spudger, pivot the top end of the motherboard up and out of the phone's frame.
  40. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 40 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 40 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 40 中的图像 3,3
    • Slowly lift out the motherboard, being careful not to snag any ribbon cable connectors.
    • The rear-facing camera module connectors loop around the motherboard, and the camera module is not secured to the phone, so it may lift out with the motherboard during this step.
    • Completely remove the motherboard.
    • When reinstalling the motherboard, check that no ribbon cable connectors are caught underneath.
  41. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the rear cameras: 步骤 41 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the rear cameras: 步骤 41 中的图像 2,2
    • Use a pair of tweezers to remove the rear-facing camera module.
  42. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the earpiece module: 步骤 42 中的图像 1,1
    • Use a T3 Torx driver to remove the 2 mm screw securing the small earpiece module board to the phone.
  43. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 43 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 43 中的图像 2,2
    • Using the pointed end of a spudger, slide the board slightly to the side, away from the top of the phone.
    • Do not attempt to entirely remove this board; it's still connected to the earpiece speaker.
  44. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 44 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 44 中的图像 2,2
    • Using the flat end of a spudger, pry the earpiece module away from the phone's midframe.
    • The earpiece module is attached with some light adhesive, and should come up without too much force.
  45. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 45 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 45 中的图像 2,2
    • Pull the earpiece speaker away from the light adhesive holding it to the phone's top frame.
    • Do not completely remove the earpiece speaker yet, as the microphone is still adhered to the phone's frame.
  46. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 46 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 46 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 46 中的图像 3,3
    • Using the pointed end of a spudger, peel the microphone away from the light adhesive holding it to the phone's top frame.
    • Ensure the microphone is completely detached from the top frame before continuing to the next step.
  47. Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 47 中的图像 1,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 47 中的图像 2,3 Google Pixel 4 XL Soli Motion Sensor Replacement: 步骤 47 中的图像 3,3
    • Use a pair of tweezers to remove the earpiece speaker and Soli motion sensor assembly.
  48. Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the Soli motion sensor cable: 步骤 48 中的图像 1,2 Google Pixel 4 XL Soli Motion Sensor Replacement, Remove the Soli motion sensor cable: 步骤 48 中的图像 2,2
    • Use a pair of tweezers to peel away and remove the Soli motion sensor cable, which is held in place with some light adhesive.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
另外一个人完成了本指南。
Carsten Frauenheim
于03/10/20注册
113,672 声望
创作了338篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 1,528
