跳转到主内容
修复你的物品
维修的权力
商店
简介
Use this guide to remove or replace the wireless charging coil on your Google Pixel 4.
Caution: The wireless charging coil is adhered to the back panel as a large sticker. It is covered by an insulating / heat-dissipating graphite adhesive layer which will need to be destructively removed and will need to be replaced.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
  1. Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone. Press firmly to eject the tray. Remove the SIM card tray.
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible. If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame. Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Slide the opening pick across the bottom towards the left corner to slice the adhesive. With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive. Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Prepare an iOpener and apply it on the left edge of the phone for one minute.
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Insert a second opening pick underneath the back panel directly over the charge port. Slide the opening pick to the bottom left corner of the phone.
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive. The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Prepare an iOpener and apply it on the right edge of the phone for one minute.
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. With the first two opening picks still in place, insert a third pick on the lower part of the righthand side. Slide the opening pick up towards the top of the phone, slicing the right side's adhesive. Stop when you reach the top right corner, and leave the pick inserted.
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive. Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book. Do not try to pull the panel all the way off yet, as it is still connected to the phone. Do not try to pull the panel all the way off yet, as it is still connected to the phone.
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable. During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  14. Use a pair of tweezers to remove the battery connector shield. Use a pair of tweezers to remove the battery connector shield.
    • Use a pair of tweezers to remove the battery connector shield.
  15. Whenever you use the spudger near the battery, be very careful not to puncture the battery. Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs. Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  17. Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  18. Use a pair of tweezers to remove the back panel connector cover. Use a pair of tweezers to remove the back panel connector cover.
    • Use a pair of tweezers to remove the back panel connector cover.
  19. Using the pointed end of a spudger, pry up and disconnect the back panel connector. Using the pointed end of a spudger, pry up and disconnect the back panel connector.
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  20. Remove the back panel.
    • Remove the back panel.
    • Before you install a replacement back panel, be sure to remove all adhesive residue from the phone frame. Use an opening tool and high-concentration isopropyl alcohol to scrape and clean the surface.
    • If you are re-using the back panel, be sure to clean off any adhesive and apply new back panel adhesive.
    • If you are installing a replacement back panel, be sure compare it with the original part.
  21. The wireless charging coil is adhered to the back panel and is covered by a graphite adhesive layer which will need to be removed.
    • The wireless charging coil is adhered to the back panel and is covered by a graphite adhesive layer which will need to be removed.
    • Use tweezers on one of the bottom corners to pull up the adhesive enough to grab it with your fingers.
  22. Peel back the graphite adhesive layer to expose the wireless charging coil, NFC pads, and LED flash module. Completely remove the graphite adhesive layer.
    • Peel back the graphite adhesive layer to expose the wireless charging coil, NFC pads, and LED flash module.
    • Completely remove the graphite adhesive layer.
  23. Use tweezers on one of the bottom corners of the wireless charging coil pad to pull up the adhesive backing enough so you can grab it with your fingers. Peel off and remove the wireless charging coil.
    • Use tweezers on one of the bottom corners of the wireless charging coil pad to pull up the adhesive backing enough so you can grab it with your fingers.
    • Peel off and remove the wireless charging coil.
    • When installing a new wireless charging coil pad, align the contacts with the residue outline left by the old adhesive.
    • If the contacts don't line up with the corresponding spring contacts on the motherboard, the wireless charging coil will not work properly.
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
另外一个人完成了本指南。
Carsten Frauenheim
于2020年03月10日注册
40,189 信誉积分
创作了239篇指南
团队
iFixit iFixit 的会员
Community
133 名成员
创作了15,587篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 11
过去的30天: 68
总计 553
