跳转到主内容
Google Pixel 4 Front Camera and Sensor Assembly Replacement
你所需要的
  1. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: 步骤 1 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: 步骤 1 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the SIM card tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Heat the back panel glass: 步骤 2 中的图像 1,1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Apply a suction cup: 步骤 3 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Apply a suction cup: 步骤 3 中的图像 2,2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Insert an opening pick: 步骤 4 中的图像 2,2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: 步骤 5 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: 步骤 5 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Begin to slice the adhesive: 步骤 5 中的图像 3,3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the lefthand-side adhesive: 步骤 6 中的图像 1,1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 7 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 7 中的图像 2,2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 8 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 8 中的图像 2,2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice righthand-side adhesive: 步骤 9 中的图像 1,1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 10 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 10 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 10 中的图像 3,3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the top-side adhesive: 步骤 11 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Slice the top-side adhesive: 步骤 11 中的图像 2,2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: 步骤 12 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: 步骤 12 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Lift up the back panel: 步骤 12 中的图像 3,3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 13 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 13 中的图像 2,2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
    At this point I suggest taking a photo of what you're seeing in there. This way you can make sure you put it all back the way it was when you're done.
    Brian Wood - 回复
  14. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the battery: 步骤 14 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
    Does anyone know where I can get a replacement T3 - 2.1mm screw (the one circled in orange)? I lost this screw during the battery replacement. Had it, dogs fought, had to get up to break it up, and couldn’t find it. I swore I put it on the mat, but I couldn’t find it when I got back to the table. :(
    Nikki Chan - 回复
  15. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 15 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 15 中的图像 2,2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 16 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 16 中的图像 2,2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 17 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 17 中的图像 2,2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the back panel connector: 步骤 18 中的图像 1,1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 19 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 19 中的图像 2,2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 20 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 20 中的图像 2,2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the back panel: 步骤 21 中的图像 1,1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
    Why does the kit not come with the back panel adhesive?
    It's not cheap to get the full kit, and it seems like it's such a small thing to include.
    I ended up re-using the existing back panel adhesive and now a bit worried that it's not as strong and I will have issues with water or moisture getting into the device more easily.
    Mike Y - 回复
  22. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Front Camera and Sensor Assembly: 步骤 22 中的图像 1,1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
    left-most screw appears to be t4, not t3
    Mark Schierbecker - 回复
  23. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 23 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 23 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 23 中的图像 3,3
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  24. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: 步骤 24 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: 步骤 24 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement, Disconnect the camera and sensor connectors: 步骤 24 中的图像 3,3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  25. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 25 中的图像 1,2 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 25 中的图像 2,2
    • Disconnect the laser module connector.
  26. Google Pixel 4 Front Camera and Sensor Assembly Replacement, Remove the front camera and sensor assembly: 步骤 26 中的图像 1,1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  27. Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 27 中的图像 1,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 27 中的图像 2,3 Google Pixel 4 Front Camera and Sensor Assembly Replacement: 步骤 27 中的图像 3,3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
    I have done the whole step twice with two different (aftermarket) cameras on a Google Pixel 4 and the first one didn’t work at all and the second one worked perfectly good but then stopped working after restarting the phone. Why? And the faceID doesn’t work when the whole thing is replaced so I put the old one back so I can use the faceID. Why did the front camera work perfectly untill we restarted the phone and then stopped working???
    Mert Köroğlu - 回复
    Maybe Google’s face ID works the same as Apple’s fingerprint or face ID module, they are bound with motherboards for security reasons.
    FROD Yeh -
结论
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Carsten Frauenheim
于03/10/20注册
110,966 声望
创作了338篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了16,579篇指南
3条评论
Does face id feature work after a replacement?
Weber Lev - 回复
It’s not an iPhone, so I’d say yes.
Skylar Ittner -
I've replaced my Pixel 4 XL front camera as instruction; but unfortunately,my face ID doesn't work after replacement. It kept showing "Enrolment was not completed. Certificate expired."
Kien Mach - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 2,731
