跳转到主内容
简介
Use this guide to remove or replace a worn battery in the Google Pixel 4. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Note: Some photos in this guide show the SIM card tray ejected from the phone. You do not need to eject the SIM card tray for this procedure.
Caution: Google warns that disassembly of the front laser assembly could result in hazardous exposure to invisible infrared laser emissions. Read their safety warnings here.
  1. Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible. If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  3. Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame. Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  4. Slide the opening pick across the bottom towards the left corner to slice the adhesive. With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive. Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  5. Prepare an iOpener and apply it on the left edge of the phone for one minute.
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  6. Insert a second opening pick underneath the back panel directly over the charge port. Slide the opening pick to the bottom left corner of the phone.
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  7. Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive. The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  8. Prepare an iOpener and apply it on the right edge of the phone for one minute.
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  9. With the first two opening picks still in place, insert a third pick on the lower part of the righthand side. Slide the opening pick up towards the top of the phone, slicing the right side's adhesive. Stop when you reach the top right corner, and leave the pick inserted.
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  10. Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive. Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  11. Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book. Do not try to pull the panel all the way off yet, as it is still connected to the phone. Do not try to pull the panel all the way off yet, as it is still connected to the phone.
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  12. Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable. During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  13. Use a pair of tweezers to remove the battery connector shield. Use a pair of tweezers to remove the battery connector shield.
    • Use a pair of tweezers to remove the battery connector shield.
  14. Whenever you use the spudger near the battery, be very careful not to puncture the battery. Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs. Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  16. Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  17. Use a pair of tweezers to remove the back panel connector cover. Use a pair of tweezers to remove the back panel connector cover.
    • Use a pair of tweezers to remove the back panel connector cover.
  18. Using the pointed end of a spudger, pry up and disconnect the back panel connector. Using the pointed end of a spudger, pry up and disconnect the back panel connector.
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  19. Remove the back panel.
    • Remove the back panel.
    • Before you install a replacement back panel, be sure to remove all adhesive residue from the phone frame. Use an opening tool and high-concentration isopropyl alcohol to scrape and clean the surface.
    • If you are re-using the back panel, be sure to clean off any adhesive and apply new back panel adhesive.
    • If you are installing a replacement back panel, be sure compare it with the original part.
  20. Pull on the yellow pull tab at a shallow angle with steady force. If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling. Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
    • Pull on the yellow pull tab at a shallow angle with steady force.
    • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
    • Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
    • This may take a lot of force.
    • These adhesive pull tabs are very prone to snapping in half during this process. Pull as slowly as possible.
    • If the adhesive pull tabs are not stretching, you can fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
    • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
  21. If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath. Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • If the battery tabs snapped during removal, insert an opening pick on the upper right edge of the battery, slicing the adhesive underneath.
    • Even if you successfully removed all three adhesive pull tabs, using an opening pick to dislodge the battery may be helpful.
    • Don't insert the opening pick on or anywhere below the grip sensor cable, as the pick can damage the charge port flex cable located underneath the battery.
  22. Lift the battery up and away from the phone to remove it. You may need to peel the battery away from any leftover adhesive tabs.
    • Lift the battery up and away from the phone to remove it.
    • You may need to peel the battery away from any leftover adhesive tabs.
    • To install a replacement battery:
    • Lay some double-sided tape in the phone's battery well, being careful not to cover the charge port flex cable. Peel away any tape liners to expose the adhesive.
    • Temporarily re-connect the battery's connector to the motherboard socket. This ensures that the battery is properly positioned.
    • Lay the battery on the adhesive and press firmly.
    • Disconnect the battery connector from its motherboard socket and resume re-assembly.
结论
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
12等其他人完成本指南。
Carsten Frauenheim
于2020年03月10日注册
53,689 信誉积分
创作了291篇指南
团队
iFixit iFixit 的会员
Community
137 名成员
创作了16,717篇指南
4条评论
If you are gonna sell me your tool kit at least supply a *!&$!&$^ T3 Tork bit to complete the job.
Nicholas Smyth - 回复
Hi Nicholas,
The iFixit kit should definitely have a T3 bit. Please contact our customer support and we will get the issue resolved!
Arthur Shi -
When you put it back together do you need to reheat the adhesive?
Keith P - 回复
Hey Keith,
When putting the phone back together and reinstalling the back panel, we recommend removing the old adhesive and installing new adhesive. The Pixel 4’s back panel adhesive can be found here, and a guide on how to install it can be found here!
If you’d like to reuse your old adhesive, try removing any large uneven chunks, reheat the adhesive, and press the back panel back into place.
Carsten Frauenheim -
添加评论
浏览统计数据:
过去的24小时: 43
过去的7天: 318
过去的30天: 1,277
总计 12,693
