简介
跟随这篇指南来移除以及更换旧的Google Pixel 3电池,如果你的电池已经鼓包,采取合适的措施.
“为了您的安全,请再拆解前将手机放电至25%以下。”这样做可以减少在维修过程中因为电池意外损坏而发生意外热量事件的风险。
你所需要的
为获得最佳性能,请校准您新安装的电池。将其充电至100%,并继续充电2小时以上。随后使用您的设备至它没电关机。最后,将其重新充满至100%
请倒序按照本指南操作来重新组装你的设备。
将电子垃圾交给有资质的回收商处理
维修不像计划中一样进行?查阅Google Pixel 3 社区 for troubleshooting help.
171等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
53指南评论
Removing the adhesive from the rear glass can be a tedious process. I got my best results by taking fine point tweezers and pulling the adhesive back slowly, trying to get it to come up altogether as much as possible before using IPA to remove any residue.
How do you put the adhesive back (or put new adhesive on) when putting the phone back together?
@bfferraro, it depends on the type of adhesive.
If you are using a pre-cut adhesive sheet, follow this guide.
If you have a custom-cut adhesive, follow this guide.
Arthur Shi - 分享
Hi mpc,
The tape does not need to be thick at all. You can use standard double-sided tape, or the fancier stretch-release adhesive.
Arthur Shi - 分享
