本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacement guide for the rear camera on a Google Pixel 2 smartphone.
This repair is extensive and requires that the motherboard be completely removed.
你所需要的
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol under each corner of the battery. Give the alcohol a minute to weaken the battery adhesive.
Alternatively, apply a heated iOpener to the back of the phone over the battery for at least two minutes. Reheat and reapply the iOpener as needed until the battery adhesive is sufficiently weakened.
Hold the charging assembly cable out of the way and insert an opening pick along the bottom edge of the battery.
Apply steady, even pressure to slowly lever the battery up and out of the phone.
Only pry from the center of the battery to avoid damaging the delicate ribbon cables beneath either side of the battery.
If you are having trouble, apply some more alcohol under the battery and try again.
在这个步骤中使用的工具:Tesa 61395 Tape$5.99
Remove the battery.
Use a spudger to scrape away any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone, not directly onto the battery. The adhesive should not touch any of the cables under the battery.
Press the battery firmly into place for 20-30 seconds.
use the flat end of a spudger to disconnect the charging assembly connector from the motherboard.
Use the pointed end of a spudger to lift up and disconnect the rear camera press-fit connector.
Remove the rear camera from the motherboard.
7等其他人完成本指南。
17条评论
Does anyone know if replacing the camera unit fixes the problem with the camera’s ‘fatal error’ issue? I’m trying to figure out if it’s just the camera unit that’s bad, or if there are other parts involved.
Sean McCay - 回复
I just replaced my rear camera on pixel 2 and I can confirm YES it does fix it!
Well, I completed the repair on the camera but cannot confirm that it worked because I messed up my display which costs too much to replace :( That thing is super delicate I guess. I’m thoroughly upset.
Yes. This fixed my Pixel 2 camera crashing issue. My original symptom was that the autofocus stopped working properly. Then a month or so later the rear camera would crash 49 out of 50 times I opened it (completely unusable). Many people online swear this is a software issue caused by an android update but because I had that focus issue crop up first I suspected my issue was physical damage. I’m generally pretty careful with my phone, it lives in an official case. The only potentially damaging behaviour my phone is exposed to is my placing it in a windscreen mounted phone holder. Perhaps the repeated vibration can break something. Now my camera is fixed I will continue to place it in the phone holder and report back if it breaks again. For science. BE VERY CAREFUL REMOVING THE SCREEN. The guide is not being overly cautious about the screen removal. I broke my screen removing it and turned my $50 camera job into a $200 job with a new screen. Still worth it but I wish I’d heeded the warnings and cautions.
Alex, you may be onto something! There have been many reports of motorcycle riders breaking their smartphone cameras after they’ve mounted their smartphones for prolonged periods. The optical stabilization hardware on these camera modules is pretty fragile. I suspect repeated vibration can definitely result in breaking some very delicate wires in the OIS or flex cables.
