简介
本维修指南由 iFixit 员工撰写,未经 Google 认可。
使用此指南来更换Google Pixel的电池。在日常使用情景下,一块电池在容量大幅度损耗前可以使用约18至24个月。如果您的手机必须不断充电或经常突然关机,更换一块电池可能解决这些问题。
请注意:因为显示器由胶水固定、可插入工具的间隙很小以及在这个过程中所需要的高温,在这个过程中很容易意外的损坏显示屏。除非你这次维修打算同时更换显示屏,否则请在更换时十分小心并做好在显示屏无法正常工作后更换显示屏的准备。仔细按照说明并注意所有警告,可以增加成功的几率。
在拆卸手机之前,将电池放电到25%以下。充满电的锂离子电池如果被意外刺穿,可能会着火、爆炸。如果您的电池膨胀,采取适当的预防措施。
电池通过非常牢固的粘合剂固定。您可能需要使用高浓度(超过 90%)酒精,以便从手机上松开电池。
你所需要的
在这个步骤中使用的工具:Suction Handle$2.99
使用 Suction Handle 来拉起显示屏并在显示屏和设备外框之间创建一个小缝隙
如果无法拉起屏幕并创造一个小缝隙,您可能需要继续加热。保持耐心,这需要时间。一旦您可以将工具轻轻地插入间隙中,请继续下一步。
请仔细比对新替换的部件和原部件——在开始安装之前你可能需要将原部件上的剩余零件移至新部件上,或者需要将新部件上的保护膜揭下。
要重新安装设备,请逆向根据以上步骤装回。
完成了这份指南后,请校准您的电池
请将替换下的部件交给有资质的电子废料回收商处理。
维修中遇到问题了?请访问我们的社区以寻求帮助。
完成了这份指南后,请校准您的电池
133等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
73条评论
I doubt many people can get past step 1 without it being game over. Take special care, read the comments, and other guides as well.
I broke mine too. Not the glass but the display panel underneath.
For those who are going to try opening theirs: pay extreme attention to the fact that the display panel extends somewhat beyond the bottom edge of the visible part of the display where the cable connects and, if that wasn’t bad enough, the bottom bezel has a !&&* of a lot adhesive on it. Don’t insert plastic opening tools on the bottom corners - if you do that, you will damage one of the unprotected corners of the panel like I did. If I had to do that again, I’d probably start from the top edge instead.
The new screen ended up costing me the equivalent of $80, and I was surprised I was able to walk into a store and buy one at all in a country where Pixel was never officially available in the first place. They didn’t have white ones in stock so I went with a black one.
Same. Even when being warned and trying to be super careful.
Another trashed screen. This phone is a difficult one if you have not done one before. I would recommend not even bothering with prying under the sides and just concentrate on the top and bottom. The edges only allow about 2mm at most before you run into the LCD.
Tyler -
+1. Don’t bother trying to save the screen. Just save yourself the stress and buy a new screen on ebay for $35 before you begin. I have never botched a repair and I still managed to break my display on this. Yes, I was super careful, it took me like 45 minutes to finally get the display loose, and when I put it all back together, the display was totally dead.
