跳转到主内容
加入维修社区 - 创建账户
Google Home Sound Driver Replacement
你所需要的
  1. Google Home Sound Driver Replacement, Interconnect Cable: 步骤 1 中的图像 1,3 Google Home Sound Driver Replacement, Interconnect Cable: 步骤 1 中的图像 2,3 Google Home Sound Driver Replacement, Interconnect Cable: 步骤 1 中的图像 3,3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Sound Driver Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Sound Driver Replacement, Mute Button Switch: 步骤 3 中的图像 1,2 Google Home Sound Driver Replacement, Mute Button Switch: 步骤 3 中的图像 2,2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Sound Driver Replacement: 步骤 4 中的图像 1,2 Google Home Sound Driver Replacement: 步骤 4 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Sound Driver Replacement, Motherboard: 步骤 5 中的图像 1,2 Google Home Sound Driver Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Sound Driver Replacement: 步骤 6 中的图像 1,2 Google Home Sound Driver Replacement: 步骤 6 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
  7. Google Home Sound Driver Replacement, Sound Driver: 步骤 7 中的图像 1,2 Google Home Sound Driver Replacement, Sound Driver: 步骤 7 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
  8. Google Home Sound Driver Replacement: 步骤 8 中的图像 1,2 Google Home Sound Driver Replacement: 步骤 8 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
  9. Google Home Sound Driver Replacement: 步骤 9 中的图像 1,2 Google Home Sound Driver Replacement: 步骤 9 中的图像 2,2
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
结论
6等其他人完成本指南。
Gabe Hyun
于04/17/18注册
844 声望
创作了4篇指南
团队
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G11
4 名成员
创作了5篇指南
4指南评论
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - 回复 分享
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - 回复 分享
Looking for replacement speaker, where do I find?
Corey Anderson - 回复 分享
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 60
总计 2,707
