跳转到主内容
加入维修社区 - 创建账户
Google Home Mute Button Switch Replacement
你所需要的
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: 步骤 1 中的图像 1,3 Google Home Mute Button Switch Replacement, Interconnect Cable: 步骤 1 中的图像 2,3 Google Home Mute Button Switch Replacement, Interconnect Cable: 步骤 1 中的图像 3,3
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Mute Button Switch Replacement: 步骤 2 中的图像 1,1
    在这个步骤中使用的工具:
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: 步骤 3 中的图像 1,2 Google Home Mute Button Switch Replacement, Mute Button Switch: 步骤 3 中的图像 2,2
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Mute Button Switch Replacement: 步骤 4 中的图像 1,2 Google Home Mute Button Switch Replacement: 步骤 4 中的图像 2,2
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
结论
另外一个人完成了本指南。
Gabe Hyun
于04/17/18注册
844 声望
创作了4篇指南
团队
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 的会员
CPSU-MANESS-S18S24G11
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 64
总计 1,228
