简介
A guide to change Google Home Mini USB power port.
你所需要的
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
Babu Vlogs - 回复
9等其他人完成本指南。
8条评论
Where I can buy micro USB PCB ?
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - 回复
Has anyone had any luck buying a replacement part?
If you're able to solder, you can find micro USB ports on Digi-Key.
Forgot to confirm the pin count while mine was taken apart, but would bet it's similar to many common ports such as PN: 10118194-0001LF
Somebody know where to buy it?
