跳转到主内容
加入维修社区 - 创建账户
Google Home Mini USB Power Port Replacement
你所需要的
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: 步骤 1 中的图像 1,1
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: 步骤 2 中的图像 1,1
  3. Google Home Mini USB Power Port Replacement: 步骤 3 中的图像 1,1
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: 步骤 5 中的图像 1,1
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: 步骤 6 中的图像 1,2 Google Home Mini USB Power Port Replacement, USB Power Port: 步骤 6 中的图像 2,2
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: 步骤 7 中的图像 1,2 Google Home Mini USB Power Port Replacement: 步骤 7 中的图像 2,2
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: 步骤 8 中的图像 1,2 Google Home Mini USB Power Port Replacement: 步骤 8 中的图像 2,2
    • Remove the board.
结论
10等其他人完成本指南。
Mia Sulaiman
于05/21/18注册
1,125 声望
创作了3篇指南
团队
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G4
7 名成员
创作了7篇指南
9指南评论
Where I can buy micro USB PCB ?
so_ang - 回复
Planet Carl - 回复
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - 回复
Has anyone had any luck buying a replacement part?
Caitlin Barnum - 回复
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 25
过去 30 天: 134
总计 7,564
