跳转到主内容
Google Chromebook Pixel 2 Speaker Replacement
你所需要的
  1. Google Chromebook Pixel 2 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Speaker Replacement: 步骤 2 中的图像 1,1
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Speaker Replacement: 步骤 3 中的图像 1,2 Google Chromebook Pixel 2 Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Speaker Replacement: 步骤 4 中的图像 1,1
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker on the right sight of the motherboard.
  6. Google Chromebook Pixel 2 Speaker Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool disconnect the speaker wires from the motherboard,
  7. Google Chromebook Pixel 2 Speaker Replacement: 步骤 7 中的图像 1,1
    • Carefully remove right speaker from the device.
  8. Google Chromebook Pixel 2 Speaker Replacement: 步骤 8 中的图像 1,1
    • Using the plastic opening tool, pop out the connector that joins the headphone jack port on the left side to the motherboard.
  9. Google Chromebook Pixel 2 Speaker Replacement: 步骤 9 中的图像 1,1
    • Remove the red 4.5 mm Phillips #00 screw from the top of the headphone jack port.
  10. Google Chromebook Pixel 2 Speaker Replacement: 步骤 10 中的图像 1,1
    • Gently remove the headphone jack port.
  11. Google Chromebook Pixel 2 Speaker Replacement: 步骤 11 中的图像 1,2 Google Chromebook Pixel 2 Speaker Replacement: 步骤 11 中的图像 2,2
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker.
  12. Google Chromebook Pixel 2 Speaker Replacement: 步骤 12 中的图像 1,1
    • Remove the left speaker.
结论
Garrett Monteiro
于04/26/17注册
413 声望
创作了3篇指南
团队
Cal Poly, Team S22-G6, Livingston Spring 2017 Cal Poly, Team S22-G6, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S22G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 87
