跳转到主内容
Golf Club Shaft Replacement
你所需要的
  1. Golf Club Shaft Replacement, Shaft: 步骤 1 中的图像 1,1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: 步骤 2 中的图像 1,3 Golf Club Shaft Replacement: 步骤 2 中的图像 2,3 Golf Club Shaft Replacement: 步骤 2 中的图像 3,3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: 步骤 3 中的图像 1,2 Golf Club Shaft Replacement: 步骤 3 中的图像 2,2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: 步骤 4 中的图像 1,1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: 步骤 5 中的图像 1,3 Golf Club Shaft Replacement: 步骤 5 中的图像 2,3 Golf Club Shaft Replacement: 步骤 5 中的图像 3,3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: 步骤 6 中的图像 1,3 Golf Club Shaft Replacement: 步骤 6 中的图像 2,3 Golf Club Shaft Replacement: 步骤 6 中的图像 3,3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: 步骤 7 中的图像 1,3 Golf Club Shaft Replacement: 步骤 7 中的图像 2,3 Golf Club Shaft Replacement: 步骤 7 中的图像 3,3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
终点
另外一个人完成了本指南。
George Bassili
于04/30/21注册
166 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 62
总计 1,329
