跳转到主内容
加入维修社区 - 创建账户
Golf Club Grip Replacement
你所需要的
  1. Golf Club Grip Replacement, Grip: 步骤 1 中的图像 1,2 Golf Club Grip Replacement, Grip: 步骤 1 中的图像 2,2
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: 步骤 2 中的图像 1,3 Golf Club Grip Replacement: 步骤 2 中的图像 2,3 Golf Club Grip Replacement: 步骤 2 中的图像 3,3
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: 步骤 3 中的图像 1,1
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: 步骤 4 中的图像 1,2 Golf Club Grip Replacement: 步骤 4 中的图像 2,2
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: 步骤 5 中的图像 1,1
    • Remove the tape backing.
  6. Golf Club Grip Replacement: 步骤 6 中的图像 1,3 Golf Club Grip Replacement: 步骤 6 中的图像 2,3 Golf Club Grip Replacement: 步骤 6 中的图像 3,3
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: 步骤 7 中的图像 1,2 Golf Club Grip Replacement: 步骤 7 中的图像 2,2
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: 步骤 8 中的图像 1,1
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: 步骤 9 中的图像 1,2 Golf Club Grip Replacement: 步骤 9 中的图像 2,2
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: 步骤 10 中的图像 1,1
    • Allow to dry at least 12 hours before use.
结论
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
6等其他人完成本指南。
Skylar Nichols
于09/30/16注册
212 声望
撰写一个指南
团队
Missouri Western, Team 1-8, Adkins Fall 2016 Missouri Western, Team 1-8, Adkins Fall 2016 的会员
MWSU-ADKINS-F16S1G8
3 名成员
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 76
总计 7,862
