跳转到主内容
GoPro Karma Propeller Replacement
  1. GoPro Karma Propeller Replacement, Battery: 步骤 1 中的图像 1,1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Propeller Replacement, Stabilizer: 步骤 2 中的图像 1,3 GoPro Karma Propeller Replacement, Stabilizer: 步骤 2 中的图像 2,3 GoPro Karma Propeller Replacement, Stabilizer: 步骤 2 中的图像 3,3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Propeller Replacement: 步骤 3 中的图像 1,1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Propeller Replacement, Propeller: 步骤 4 中的图像 1,3 GoPro Karma Propeller Replacement, Propeller: 步骤 4 中的图像 2,3 GoPro Karma Propeller Replacement, Propeller: 步骤 4 中的图像 3,3
    • Extend the arms and set the drone face up.
    • The front right and back left propellers unscrew clockwise.
    • The front left and back right propellers unscrew counterclockwise.
  5. GoPro Karma Propeller Replacement: 步骤 5 中的图像 1,2 GoPro Karma Propeller Replacement: 步骤 5 中的图像 2,2
    • Place the GoPro Karma wrench on the motor.
    • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
结论
Jay Ingram
于04/19/18注册
334 声望
创作了3篇指南
团队
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G14
4 名成员
创作了6篇指南
2条评论
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - 回复
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 1,576
