跳转到主内容
GoPro Karma Landing Gear Replacement
你所需要的
  1. GoPro Karma Landing Gear Replacement, Battery: 步骤 1 中的图像 1,1
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: 步骤 2 中的图像 1,3 GoPro Karma Landing Gear Replacement, Stabilizer: 步骤 2 中的图像 2,3 GoPro Karma Landing Gear Replacement, Stabilizer: 步骤 2 中的图像 3,3
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: 步骤 3 中的图像 1,1
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: 步骤 4 中的图像 1,1
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: 步骤 5 中的图像 1,1
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: 步骤 6 中的图像 1,2 GoPro Karma Landing Gear Replacement: 步骤 6 中的图像 2,2
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
结论
Jay Ingram
于04/19/18注册
334 声望
创作了3篇指南
团队
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 的会员
CPSU-MANESS-S18S25G14
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 7
总计 590
