简介
Replacing the landing gear in your Karma is a relatively easy task, but requires caution because of small screws. There is a specific tool to help remove the clips connecting the arms but it is not necessary at all. Removing the clips without that tool can be tedious and requires a soft touch so be sure to go slow.
你所需要的
Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
另外一个人完成了本指南。
