跳转到主内容
  1. Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off. Use the tweezers to lift the faceplate  from the rest of the device. The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. Using a #00 Phillips head screwdriver, remove the following screws: One 4.6 mm screw
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection. Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard. The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
结论
Thomas Sullivan
于2017年02月20日注册
580 信誉积分
创作了3篇指南
团队
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G1
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 49
