跳转到主内容
简介
If the pictures or video are fuzzy or unable to focus, the lens may need replacement. Follow this guide to do so.
  1. Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off. Use the tweezers to lift the faceplate  from the rest of the device. The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. Using a #00 Phillips head screwdriver, remove the following screws: One 4.6 mm screw
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera. Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection. Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard. The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. Using a plastic opening tool, separate the camera sensor's connector from the motherboard. Using a plastic opening tool, separate the camera sensor's connector from the motherboard. Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor. Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. Using a #00 Phillips head screwdriver, remove the following screws: Three 2 mm screw
    • Three 2 mm screw
  8. Lift the lens from the front housing.
    • Lift the lens from the front housing.
结论
5等其他人完成本指南。
Thomas Sullivan
于2017年02月20日注册
580 信誉积分
创作了3篇指南
团队
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G1
4 名成员
创作了12篇指南
一条评论
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 25
总计 3,564
