简介
Use this guide to replace a malfunctioning motherboard or expansion port. Because replacing either part requires the same steps, they are both combined into one guide.
你所需要的
Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
Use the tweezers to lift the faceplate from the rest of the device.
Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
Using #00 phillips head screwdriver, remove the 3.0mm screw.
Using the plastic opening tool, unclip the LCD ribbon from the motherboard.
9等其他人完成本指南。
一条评论
step 2 is wrong, short screw belongs on the battery door edge... destroyed my new housing... :(
