跳转到主内容
GoPro Hero4 Black Camera Sensor Replacement
你所需要的
  1. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 步骤 1 中的图像 1,3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 步骤 1 中的图像 2,3 GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Camera Sensor Replacement: 步骤 2 中的图像 1,2 GoPro Hero4 Black Camera Sensor Replacement: 步骤 2 中的图像 2,2
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Camera Sensor Replacement: 步骤 3 中的图像 1,2 GoPro Hero4 Black Camera Sensor Replacement: 步骤 3 中的图像 2,2
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Camera Sensor Replacement: 步骤 4 中的图像 1,3 GoPro Hero4 Black Camera Sensor Replacement: 步骤 4 中的图像 2,3 GoPro Hero4 Black Camera Sensor Replacement: 步骤 4 中的图像 3,3
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 步骤 5 中的图像 1,3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 步骤 5 中的图像 2,3 GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Camera Sensor Replacement: 步骤 6 中的图像 1,3 GoPro Hero4 Black Camera Sensor Replacement: 步骤 6 中的图像 2,3 GoPro Hero4 Black Camera Sensor Replacement: 步骤 6 中的图像 3,3
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
结论
8等其他人完成本指南。
Jeffrey Goethe
于02/20/17注册
674 声望
创作了3篇指南
团队
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 的会员
USFT-SULLIVAN-S17S2G1
4 名成员
创作了12篇指南
2指南评论
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
popoypoi22 - 回复
Hi, is the sensor for black and silver same? Thank you
Jakub Kunický - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 24
总计 4,318
