跳转到主内容
GoPro Hero3+ Black Edition microSD and Accessory Board Replacement
你所需要的
  1. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Battery: 步骤 1 中的图像 1,1
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
  2. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 2 中的图像 1,1
    • Use the battery tab to pull the battery out of the device.
    • Remove the battery from the slot.
  3. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Front Face Plate: 步骤 4 中的图像 1,2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Front Face Plate: 步骤 4 中的图像 2,2
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
  4. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: 步骤 5 中的图像 1,3 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: 步骤 5 中的图像 2,3 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, Image Sensor: 步骤 5 中的图像 3,3
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
  5. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 6 中的图像 1,2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 6 中的图像 2,2
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
  6. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 7 中的图像 1,1
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
  7. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 8 中的图像 1,1
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
    Removing this and attempting to reconnect the connector ribbon will be really difficult when re-assembling. If you are simply replacing the LCD screen I recommend skipping to Step 13.
    Devin Roach - 回复
  8. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 9 中的图像 1,2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 9 中的图像 2,2
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
  9. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement, microSD and Accessory Board: 步骤 10 中的图像 1,1
    • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
    The threads on the top left screw are different so be sure to take note of which screw is which (although maybe it doesn’t matter that much).
    Devin Roach - 回复
  10. GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 11 中的图像 1,2 GoPro Hero3+ Black Edition microSD and Accessory Board Replacement: 步骤 11 中的图像 2,2
    • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
    • The microSD/accessory board is ready to come off.
结论
6等其他人完成本指南。
Kyle Rooney
于04/14/15注册
502 声望
创作了3篇指南
团队
Cal Poly, Team 6-15, Maness Spring 2015 Cal Poly, Team 6-15, Maness Spring 2015 的会员
CPSU-MANESS-S15S6G15
4 名成员
创作了13篇指南
一条评论
I bought a replacement from iFixit. I follow the guide, but it still shows same error “No SD”. Any advice?
Daniel Nielsen - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,083
